81 - 100 of 192 Posts
problem istalling inpa
Hi all
I do have a bmw inpa cable and software installed on my pc
But im finding it hard to install.
Please can some one have.
I also have team viewer install ,you can remote link and help me please.
Regards
Yash
Anybody based in the midlands that can help me?? total noob at this and cannot get it to work
Keep getting A LZH File missing? reinstalled but cannot get it to work
Cannot download software link broken
2. Download the software
There are many sources on the internet for INPA/EDIABAS, some seem to work, others do not - I used these specific downloads and they worked perfectly:
Comcast
Comcast
If for any reason the above links are missing/broken, PM me and I'll see what I can do. Thank you to whomever is hosting the above files and I hope that you do not mind me providing these links.
Guys I am having issues trying to download the INPA software as the supplied links are broken. Is there another link I can use? Also are both the old version and new version of INPA included? It seems we need to install INPA 4.4.7 then upgrade to 5.0.2. Does this sound about right?
thanks
Comcast
Comcast
thanks
Both links appear to be dead
Error message
Trying to install the EDIABAS, page 15 of the PDF file. When I select BMW group rectification programs UK there UNLHA32 error report (on UnlhaMain : 2) ,
and the message says A LZH Archive not found. : ‘C:/DOCUMENTS.LZH’
I click “ok” and another error comes up and says “Fatal error – Error 11006: Application-defined or object-defined error Errorcode: 8029. This installation process will be canceled!”
If I click the option “! No configuration !” , theres only two options I can tick…
EDIABAS 6.4.3
INPA 4.4.7
I tick complete, and on the next page click OBD, when I go to start the installation the same error comes up. Ive been trying to google this for some time now and haven’t been able to find a solution. Any help would be much appreciated.
Glen.
thank you
loaded & installed by you guide, working fine.
after 5-10 minutes connection with vehicle, flat tire monitor error appears on ccc screen, think due fact of some can bus misunderstandings. was the same error with buddy's inpa installed on xp.
successful inpa and edibas however not ncs
Hello, i followed the install instructions to a t and was successful in getting inpa and edibias to install correctly and working. However i cannot start ncsexpert. I keep getting an error stating this software is not compatible with operating system. This is of course after i already ran compatability troubleshooter and set it to run in xp sp3 as well as run as administrator. Any ideas?
Nevermind, i found my answer. ncsexpert will apparently only work in windows 32bit operating systems. If anyone knows how i can accomplish this with windows 7 please advise.
Very helpful thread
Ive managed to completely install both ediabas and INPA without a problem, the k+can OBD ive got didnt come with install discs, so I may purchased the one you reccomended although im currently downloading some k+can drivers so fingers crossed.
Firstly, i'd like to point out that im using 64 bit windows 7, And upon opening device management, on the Universal serial bus controllers tab, I get 6 'usb root hub', 4 'standard open HCD USB host controller', 2 'Standard enhanced pci to usb host controller', and one 'usb composite device'. I cant seem to find a COM port to assign as 1 and set the delay.
I proceeded with the install, mainly just to see if it would work and it seems to have done, I just need to wait for the drivers to download, and hope my laptop recognises the k+can OBD that I have.
So now onto my questions,
1. if my laptop (after installing the aforementioned drivers) still will not recognise my OBD, is my onlly option to purchase another one (such as the one recommended) and install any software/drivers that came with it?
and 2. Although im grateful for the tutorial.... if NCS expert only works with 32 bit windows, then why is it in a tutorial for x64 windows? Am I missing something?
Anyway, thanks for any help in advance.
Stu
64 bit
Good news I've installed INPA on our new 64-bit Laptop.
Spec,
Win 7 Home Prem
Service Pack 1
Manu, Samsung
Processor AMD A6-3410MX APU Radeon(tm) HD Graphics 1.60GHz
Ram 6 GB, 5.8 GB usable
System type 64 bit operating system
I hooked up the Bimmer a May 2000 328Ci coupe and I'm able to access all diagnostic areas, the install was just as straight forward as the 32-bit install. I just followed the PDF instructions that came on the install disk. I've provided a link to the ebay seller where I bought my kit so I can't really comment on any other install.
Regards
Njoro,
I don't suppose you'd be willing to share the software you used would ya? I've tried two setups now and can't get anything to work. It keeps telling me that I don't have the right version of Windows to run the INPA. And since you're running a Samsung 64 bit like me, maybe you can help. Can anybody help!?
Questions for E46 318ti Airbag failure
Hello,
thanks for your excellent guide for installing inpa ediabas on my Win7 64bit system. Installing ist completed now and prog works. but if I start Inpa and navigate to "Info" (F1) the Number behind Version says 5.00, is this a failure in installation or is it normal that the the versions number is wrong, I thought i downloadet 6.4.3?
Futhermore, I have some problems with the Airbag in my car, I tryed to read the failures in my ecu, but following messege is showed: 'IFH 0009 NO RESPONSE FROM CONTROL UNIT'. Where are the failures for airbag stored, is E46-->Body-->Airbag right?
Thanks to all.
Hi
Im wondering if anyone can help i have DIS operating on my laptop running windows vista. The software worked fine diagnostics were fine and it all worked it bought the software from ebay a few years back and came with a usb diagnostic plug i got it all setup following the instructions no problems. Then
I gave my laptop to my brother to play with on his e46 and now i have it back i have just tried to use DIS but am given the following message: Diagnosis Bus error, Communication between operating unit and diagnostic head is impaired. error number 200.166.
Does anyone know how to cure this?
Thanks for the write up buddy.
Had to do a couple of things differently in order to get it working...
1. Step_2_INPA didn't seem to do much and no shortcut appeared on the desktop and I couldn't find the files mentioned in Step10. I went in to the BMW Tools folder --> Programminstallation --> then ran 'setup' in XP compatibility mode and admin rights. This installed ok and put the shortcut on the desktop.
2. When running INPA the screen was empty with only 'F1 information' and 'f10 end' showing. To fix this I ran Step_2_INPA again and it installed properly.
There must have been a problem with the 'step_1_BMW_Tools' installation. Maybe I got something wrong, but I did follow the guide word for word.
Anyway, maybe the above will help someone.
The above was done on a MacBook Pro running Windows 7 via parallels. Haven't bought the cable yet so that's the next challenge.
no succes!
hello!
i tried and retried to install INPA on my windows 7 home premium 64 and it did not work, i followed step by step installation instruction and at "STEP 1_INSTALLATION BMW TOOLS" it stopped with the message "not compatible with windows 7...is compatible with Windows xp ..."
SHOULD BUY WINDOWS XP?
Hi everyone.
I am new to the forum. I have been facing some probs with my airbag light. It stays on. I have purchased ELM327 v1.5 bluetooth adapter from ebay and also purchased and downloade Torque software on my android phone. It doesnt show the airbag or my parking sensor fault when i run the scan and therefore when i clear the codes it doesnt go away.
Can anyone please help me how to get the airbag light removed using the bluetooth adapter?
I don't think that's possible - the software you have downloaded and the lead you have bought wont communicate with the airbag module in your car.
If you have the 16-pin OBD II port under your dash near the pedals then this should work :
http://item.mobileweb.ebay.co.uk/viewitem?itemId=150842075176
And using this thread to install the software :
http://www.bimmerforums.co.uk/forum/f99/guide-installing-inpa-ediabas-windows-7-64bit-t103023/
