61 - 80 of 112 Posts
Hi dailydoggy
Can you please send me a link for the download of INPA
The cable set that i have is from Cable-Shack this is a K-Line cable and a 16-20 pin OBD adapter.
e38 2.8 2000 will this set up work for the codes on this model or do i need something else for this to read.
Regards
Gboy
Inpa i got working and now understand it well... its dis i struggle with i cant get it to work even tho i imstalled it of a disc it still needs setting up after watching a video on youtube i still couldnt get it to work as i couldnt find the things he was selecting lol gave up in the end
INPA
if you want a known working good copy of INPA PM me for download link its modified slightly with the FDTI drivers and this guide etc...
Hihttp://www.bimmerforums.co.uk/forum/images/smilies/happy/thumbsup.gif
I appreciated your post. I got the interface cable at Ebay but the Sw I received has many german scripts whiches I don't understand at all. Could you please post me the link where download the english version of INPA.
My OS is win XP SP3
Thank you in advace
Bye
Andrew from italy
Discussion starter · #67 ·
petrols is usually mostly english i think i dont know on the 318 somebody else may confirm?
330 petrol is mostly english but as its, factory beta diags software, its not a complete finished product, and has some german script here and there the important bits are mostly english...
I had a german version before that came with a cable, ended up binning it and buying another disc off ebay.
Having a problem changing laptops now if anyone can help? Ive been using an older one with a serial lead and version 5 of INPA, no problems with battery or ignition lights. Ive now changed to a laptop with only USB ports and am using a lead I had off a mate, it has BMW Cables on a label on it, I've loaded the same version 5 of inpa and was getting a WIN32 error which maybe part of the problem, but inpa starts up fine, shows battery light constantly but no ignition light, works as far as selecting the ECU type, then gives an error cannot connect to control unit
Is it likely to be a compatibility issue between the version of inpa and the lead?
Hi mate
I sent you a pm about download link... Im sure you get it alot hehe. I just bought a 318i and looking to set up some diagnostics.. Cheers.
Luke
Thanks for the guide & download
Just to say thanks to dd for the idiots guide - worked like a charm on my Win 7 laptop with an £8 Ebay lead I found by searching for "vagcom FT232RL". I did the soldering trick on pins 7-8 and used it to clear an airbag error needed to pass the MOT on my son's 325 ti. He had the classic airbag duff wiring problem under the passenger seat. The local dealer wanted £40 just to do a diagnostic check, plus god know how much to fix the actual problem. So we managed to sort it with some electrical contact cleaner and the magic lead + INPA - thanks to dd. Big Cheers!
Dailydoggy, thanks for the link. I'm sure I'll be back with questions. Was starting to worry inpa did not work on Alpinas. Turns out, it was the cable. Got one with green circuit board from Germany and it works great now.
Had a broken wire in the boot gaiter that I didn't notice, caused a short out error on he light module and now no reverse or internal boot lights. Need to read up on resetting the short out error on the light module now. I know it can be done.
I'll let you know how I get on.
Cheers for the link again!
Discussion starter · #80 ·
not really depending on car most of its in english but it was never software for mainstream use it was factory software not finished retail or issue software...
