this is hopefully idiot proof Installation instructions for INPA with Windows XP Pro (32-bit) and a modded £7 Vagcom USB interface off ebay this is the original guide created by myself, any other versions found on the net are stolen copies of it or not by myself.
Firstly open up your £7 Vagcom cable (sold on ebay by various sellers) (note you must source a vagcom with either FDTI ft232RL or BL chipsets, RL chipset allows chip flipping/ignition detection fooling for NCS or SSS encoding) interface by removing the 4 x phillips screws on it
Get yaself a fine soldering iron and with a blob of solder,solder pins 7 and 8 together on it and put it back together…
NOTE:you can buy a dedicated BMW cable instead if you want ignition and batt sensing indication in INPA and dont want to solder anything, but they are more expensive around 20-25 quid..
Ive used this install method without fault on umpteen machines now and not had to amend any registry settings or anything, its worked first time everytime this way..
there is a myth you have to use com port 1 with INPA this is total cobblers! you can use any com port number you like as long as the INPA OBD.ini file port selection matches your actual com port setting on the vagcom interface you have set..
First things to do is Download the 326MB version of BMW INPA from a torrent site or anyware you can get it ( and extract it to a folder on your machine..
you also may need to download the FDTI VCP (virtual com port) driver for windows XP for the Vagcom USB interface from the FDTI website, unzip it to a folder and copy this folder to the 326MB INPA installation software folder so you know where it is and for any future installations...
1. Insert your modded OBD-II-USB vagcom cable into your usb-port
-once it is detected by windows and prompts for the driver (at this point windows may find the drivers for you depending on the vagcom type) point it towards your FDTI vcp driver folder in the INPA folder if windows fails to find the drivers…
It will then install the drivers (it will probably go thru this process twice just repeat the process)
In the windows Device Manager, you should now see [Ports COM & LPT] ->> "USB Serial Port (ComX)
right click this and click properties/port settings /advanced.
at the top change your port number to your selection( if you do not wish to move or force a device on COM1 to another port because its already being used just select an unused port usually COM2 is unused) just remember your port selection for the INPA\install.
Now change the transmit and receive settings in the drop down boxes to 2048 for both transmit and receive
Now change the latency setting from 16 to 1
Ok the changes and exit
The usb vagcom cable is now setup.
2. Always use SAME USB-port from now on.
3. Installing INPA you must copy and paste your downloaded complete INPA installation software folder to your C drive.
in your INPA folders click programmisation then double click setup.
It should default to English so ok this.
Click next till you get to the selection for software to install.
Select or deselect in options boxes but as a minimum select INPA ,EDIABAS and NCS expert if you want it.
Click next you will be asked to backup and restore (I declined this , unticked the box and skipped it all)
Make sure quick launch and desktop icons are ticked.
Click next.
Now select STD-OBD in drop down box (should be by default).
Click next.
Now select the com port number you selected earlier from the drop down box and tick the USB to serial adaptor box.
Click next and install (if it ask for backup and recovery just click skip to these prompts if you wish)
Finish install
Reboot
Now go to C/ediabas/hardware/OBD/OBDsetup.exe
Double click OBD setup.exe
If all is well you should get a black DOS box up with various settings shown with a full house of ok’s on them, you may get the start one saying warning instead of an ok if you have selected an alternative com port just ignore it)
press any key to exit if the list is ok.
Reboot
Go to C/ediabas/bin..
Find the OBD.ini or OBD file and double click
Your settings will be dispayed make sure they read as below
PORT= COM? (your com choice entered and set earlier)
HARDWARE=USB
RETRY=ON
UBAT=OFF (type this command in manually in this position)
Exit and save
Right click andCopy the amended OBD.ini file and paste it into your C/windows folder
Now go back to the INPA \install folder on C drive.
Open C/INPA folder/REFERENZ/INSTALL.
Double click instprog.exe
Ok the german writing page
Select English and continue.
At destination drive page make sure C drive is selected and continue.
Now select BMW “GROUP RECTIFICATION PROGRAMME UK” from the list and click continue
Now select the following:
Ediabas tick update box
INPA tick update box
NCS expert expert tick complete box
click continue
Tick the box “delete the old NCS expert “
Click install
double check that C:\EDIABAS\BIN has been added to the path string in enviromental variables (right click my computer/properties/advanced/enviromental variables and select path in the list, click edit check its there and exit without changing anything)
Thats it you should be done and ready to get diagnosing:thumbsup
Always use the SAME USB port on your laptop when using the software…
i dont think ive omitted anything and i take no blame if you goose your car messing around with INPA software and dont PM me if you feck things up with it, post on the forum for a solution:thumbsup
PS if you want to do recoding with NCS expert (highly doubtful like its in german and impossible) you need ignition sensing which you dont get with a Vagcom but you can flip the FDTI chip (FT232RL chipset) on the interface with Mprog software to fake the batt and ignition sensing so you can encode...
Vista (32 bit)
here is my successful INPA install method for Vista (i have been told it works for WIN7 32 bit too)....
1. Firstly again open up your £7 Vagcom interface by removing the 4 x phillips screws on it
First things to do is Download the 326MB version of BMW INPA from a torrent site or anyware you can get it or just PM me If you want a known good working version to download, i have uploaded it zipped with WinRar with the FDTI drivers included just extract it to a folder on your machine...
IF YOU HAVE YOUR OWN COPY you also may need to download the FDTI VCP (virtual com port) driver for some windows OS's for the Vagcom USB interface from the FDTI website, unzip it to a folder and copy this folder to the 326MB INPA installation software folder so you know where it is and for any future installations...
Virtual COM Port Drivers
.NOTE THIS INSTALL METHOD IS FOR WINDOWS VISTA 32 bit ONLY!
-once it is detected by windows and prompts for the driver if it does not find the driver then point it towards your FDTI vcp driver folder in the INPA folder…
In the windows Vista Device Manager (computer/system properties/device manager), you should now see [Ports COM & LPT] ->> "USB Serial Port (ComX)
3. Installing INPA you must Copy and paste your downloaded complete INPA installation software folder to your C drive.
In your INPA folders double click the programmisation folder- then right click the setup icon and select “Properties/Compatibilty mode select XP service pack 2 and tick the box, click the apply button and exit now double click the setup icon and begin the setup.
Make sure quick launch or desktop icons are ticked.
Click next.
Click next
Select Com port number (you selected earlier) in the drop down box, tick the USB serial adaptor box
Finish install and Reboot
If all is well you should get a black DOS box up with various settings shown with a full house of ok’s in Vista this will be full of errors and missing OK’s we shall address this later with a registry edit..
press any key to exit the list.
Reboot
HARDWARE=USB
RETRY=ON
Exit and save
Right click and Copy the amended OBD.ini file and paste it into your C/windows folder
Right click Instprog.exe/Properties/Compatibilty select windows XP service pack 2 and tick box and apply and exit.
Double click the instprog.exe and install
Click continue
Click install
Double check that C:\EDIABAS\BIN has been added to the path string in enviromental variables.. (Computer/System Settings/Adavanced System Settings/Environmental Variables” click edit check its there and exit without changing anything)
You can now test INPA on your car it will work with the INPA diags only and you will get error warnings with Ediabas running because of the OBDsetup command errors earlier,to address this copy and paste the following below into a notepad folder, save the file to your desktop and name the file “serial.reg” and select all files and save…
You must copy and paste all the above icluding the windows registry bit or it will not execute to the registry later.
You now need to backup the registry just in case so you can restore it if need be...
Click the windows icon start button bottom left on desktop and type in regedit in the small box and press enter to access the registry
Click file then Export and name the file something of your choice and select ALL in the export range box and save it to somewhere safe..
Now double click the serial.reg file and apply it to the registry (right click the file and open with registry editor if it opens in notepad by default)
Go back to to C/ediabas/hardware/OBD/OBDsetup.exe
Double click setup the blackbox should be clear of errors (you may get 1 if you have selected an alternative port number other than COM1 ignore it)
You now should be good to go with full functions and no error messages when using your INPA…
DD, Thanks for the writeup.
I have the Vagcom cable and soldered pins 7 & 8 together.
I received a CD with my cable, will this have the drivers for the cable. I have not yet checked as the label only says Vagom.
I will try it later, however do you have a link for the drivers you have quoted above.
Sadly at no point during the install is that a selectable option? The issue seems to be that in following the guide after installing INPA you are asked to:
i) right click "my computer" => "property" => "advanced" => "environment value(N)"
ii) choose "system value(S)", find "path" and then add ";C:\ediabas\bin" and then save
However, it seems that Vista does not have the same menus or options as the older XP under "my computer" "property..." tabs and so on, and in the IT world it has moved on a bit in terms of OS. There is no "environmental variables" tab in Vista, or "path option" to chose and save to.
Hence I am stuck!
Does anyone ever manage to run INPA on Vista, or do you all have old rat-laptops you hold onto just for this purpose and reading codes on BMWs?
I run it on Windows 7 Ultimate N and Windows 8 Consumer Preview. In Windows Vista, try: Start Menu > Control Panel > System and Security > System > Advanced System Settings (System Properties) > Advanced - you should see Enviroment Variables at the bottom.
Thanks guys for the help. I still couldnt get Vista to work out, so I have lucked upon an old rat-laptop from a friend that runs XP. He has gifted it to me!
INPA runs fine, just need the lead now, which I guess means eBay...
anybody who wants a good known working BMW INPA software setup PM me, i have modified the folder slightly by adding the USB interface FDTI drivers, and a copy of this install guide, its zipped up with WinRar i also have WinRar uploaded aswell...
nope its uploaded to a personal file dump website i only give the link out to ppl who pm me......if somebody posts the link publicly on a forum after i have pm 'd it i shall take it down altogether...
you can get other versions on torrents but they are hit and miss if they contain a virus,or in the wrong language or just dont work at all...
Hi guys, does this mean I can use my old Audi A4 Vagcom USB lead to interrogate my 2001 E46 ?
It looks similar to the lead pictured but only has pins on 2,4,5,7,10,15 & 16.
If I soldered another pin in position 8 and linked it to 7 would that work or do I need all 16 connected ?
Hi guys, been searching through the posts looking but taking ages, anyone recommend a decent scan tool that can read X3 and x5? Dpf regen preferred as seen some offer it and some don't, looking at under £150 if possible, me and my brother need one for various faults, I'd like be able to read as...
I need some help figuring this out.
I put a m50 2,5 single vanos in my driftcar (car has no original wires left)
But the engine has the original wiring loom, and as far as i know, it should be able to run on a few wires, but it wont do as its told.
Ecu is the silverlabel 413 with chip to remowe...
Installation guide Bmw Standard Tools INPA Fxx Updated Sp-daten v65
This is Updated BMW Standard Tools full version - working 100% - very easy installation
Sp-daten has been updated to v65 to be sure it covers as many function as possible.
Comes with:
NCS expert - coding (profiles...
Hi I have a fault with my 2010 318d touring. I have Carly BMW and this is what it is coming up with. Can anyone help me out please
Carly for BMW - detailed Fault-Code Log
Found Faults:
--Engine / Motor--
* 483C:Boost pressure plate *
Fault-Set 1 - ( 222488 km)
Activation period for the...
