So basically guys, it looks like the end, my loan car that i have only had a couple months with a whole load of installments to pay off left is apparently a gonna. '[inking' caused by pre ignition is apparently a likely cause of my rattle when accelerating, sounds like spark plugs when you hold them close to something metal.
please dont suggest using higher octane fuel because where i live that costs a fortune and also is too simple to fix my issue anyway.
My local mech said all they can do is try re adjust it on their computer and if no hope then its ready to bin. Useless advice considering i work everyday to pay it off, nobody wants to buy a broken car?
Someone please tell me what the hell else i can do? i had some fault codes come up when i last plugged it in but i thought this was just cas of my crappy air filter that was put on and quickly removed to resolve the check engine light but now im thinking maybe its another warning as to possible ignition 'pinking'
fault codes
p0313 ( misfire caused by low fuel)
p1084 (fuel mixture control rich) - think this is just to do with air filter as i thought it was lean mixture that caused pinking)
p0056 ( 02 sensor failure )
if it is an 02 sensor failure would this cause pinking? does anyone on this forum have any sort of knowlage on this
fault codes
