Hi all.
hope your all well.
Was driving to work yesturday (25mile trip there & 25 back home)
half way there my dash went ping & a yellow picture came on & a discription. (cant recall now off top of the head what they are,).
I got to work & was hoping all was ok for the return home, but no.
I thought beens the weather is being -2 -3 c thought it may be ok when warm. ,no.
I plugged my autel maxidiag md805 into the car today, & left it connected while we went the tesco (15 mile out & 15 back)
It gave me only 1 code..(thank god..)
Code ... P0401 exhaust gas recicrulation flow insufficient detected
This is recorded in the freeze frame.
On this freeze frame report, it also gives me figures on other headings...
DTC = P0401
CALCULATED LOAD VALUE = 36.9 %
ENGINE COOLANT TEMP'' = 97 ''F
INTAKE MANIFOLD ABSOLUTE = 14.9 psi
VSS = 0 mph
INTAKE AIR TEMP'' =81 ''F
AIR FLOW RATE FROM MASS AIR FLOW SENSOR = 0.04 lb/s
i cant recall now, if i did this freeze frame test after i got to tesco or half way as i had to stop for fuel.
Does the above code mean my DPF is now fecked .... again.?
When i say again, about 1year & half, (18months) ago -ish, my dpf was blocked & was told how bad by the guy telling me the %.
We removed it & had it profesionally cleaned. All put back together.
Back in november just gone i had my NCT (im in ireland) in the Uk you'l call it MOT.
& the emission test came back as basically 0.01
So to me it looks like i map be ok with my dpf (..im hoping...please say yes im ok).
I have live data on the same test if this is a help to any one that can help me with the fix..please.?
Also can any one tell us if my other readings in freeze frame are good or bad (obviously they must be bad to report a Code)
thanks all. hope you can help me please.
hope your all well.
DTC = P0401
VSS = 0 mph
