Hello
I just want to start of by saying thank you for such a helpful community. There are some great advice and solutions.
I thought I'd share with you all my ongoing experience with troubleshooting codes P0721 (Output Speed Sensor) and P1732 (Shift Malfunctions)
Back in April 2011 My E46 330ci starting generating the above codes, the tranny would shift into 'Limp-home mode' and I'd be stuck with 3rd gear until the codes were removed or resolved.
I searched high and low for the answer, sent my car to 3 independent tranny specialists and even sent it to BMW for a full fault diagnostic twice! The results were everytime: Transmission is slipping, you need a new transmission! (My car has only done 50,000 miles).
I eventually gave in and had the transmission replaced.
To my horror! after driving away from the garage the car pulled the same codes again... nightmare! so I took it straight back.
Anyway cutting a long story shorter! the garage tested and tested and eventually came back to me with; your car stereo can cause this problem, so can the size of your tyres and even the Output Speed Sensor.
So, left with no options; i replaced all tyres, new stereo system new speed sensor.
After all this, feeling broke I thought I'd go for a drive to make myself feel better!........ Car pulls the same codes again...... great WTF!
I then take the car to an auto-electrician and for £300 I have the tranny wiring loom removed and checked, sensors checked, ecu checked and I get the result of: Your Wiring and Electrical System are sound! the problem is your transmission although there was a software update for your car from 2003 which has to be done, so it was done for me.
I am currently waiting to get my car back, but I am now faced with replacing the transmission again (not a problem as it is under warranty).
This is the story so far, I want to keep you all posted as I have found this forum to be excellent and if this helps anyone from having to spend their life savings due to incorrectly diagnosed problems, then great I've helped save someone money.
On the otherhand if anyone can offer any advice, please do I open to questions/criticisms/anything! I just want my car back up and running!
Overview of Costing To Date:
1. Fault Diagnostic (BMW) £111
1a. Fault Diagnostic (BMW) FREE
2. Fault Diagnostic (Kartech) £75
3. Transmission Replaced £1980
4. Car Stereo £340
5. New Tyres (all round) £500
6. Output Speed Sensor £75 (inc. Labour)
7. Auto Electrican £300
I'll post the next update tomorrow when I get the full diagnostic report from the auto electrican.
4. Car Stereo £340
