Yep, wiring is as Slowtech said:
The side lights are on stalks which you twist and pull out of the back of headlight reflector, then unplug the stalk. Inverter wiring has small flat pins at the end of the wires which slot directly into the wiring plug you unplugged the stalks from. Tape them up with some electrical tape and you're good to go. A bit of clear sealant on the back of the rings is a good idea, aswell as sealing the hole left from removing the stalks to prevent condensation when it's cold.
