2000 e46 323i throwing p0340, p1519 and p1520 codes
3.1K views 1 reply 2 participants last post by  mojojojo
#1 ·
Installed new intake camshaft sensor to no avail. Checked voltage and resistance to supply, target and ground wires- all within spec 12 volts supply wire; 5 volts target wire and goes to zero when cam is turned and resistance on grnd wire. Cleaned ecm contacts and connectors with electric spray. Can a bad vanos throw these codes?. Car is sluggish in low rpm but otherwise runs great; only has 75k miles on it. Any ideas would be appreciated cause I'm stumped.
Thanks Joe V 856-589-2895
