Please help
My 320d is burning oil. Its using about 1litre per 6000miles. The car has done 156,000miles now and had the usual new turbo at 100,000. There arent any drips on the outside of the engine or on to my drive. When under throttle load (more than a fairy touch on the accelerator pedal) i contribute to the hole in the ozone layer considerably. During the day you can see black and slight blue smoke but in head lights at night all you can see is smoke!!! Its fine if i potter around bit is embarrassing if i actually need to accelerate.
I do know that one of the glow plugs need replacing but surley this wouldnt be the cause of the oil burning but would be for the black smoke. I've had the EGR of and given that a good clean. I 've had the pipe of inbetween the air box and the turbo and crank case breather off and there was a little puddle on oil in the bottom. The crank case breather has been replaced but still smoke under load.
Advice needed please, are my piston rings on the way out?
Thank you
Thank you
