N52 Problems
4.1K views 7 replies 3 participants last post by  sajn
#1 ·
Just wanted to compile a list of problems to tackle and ask others which issues they have had and solutions, Purchased N52 with 160k Miles.
Below is list of common problems if anyone can add to list or advise would be great.
Current issues:
  1. Gears difficult to select
  2. Oil around gasket cover
  3. Fuel cap wire broken
Common Issues:
  • Thermostat (60 to 80K)
  • Spark Plugs (60k)
  • Water Pump (80K)
  • Valve Stem Seals (80 to 100K)
  • Vanos Solenoids (100K)
  • Timing Chain (300K)
  • Serpentine belt (60 to 80K)
  • Ignition Coils (120 to 140K)
  • Crankshaft seal front and rear (130K
  • Carbon deposits in cylinder (Anyone done terraclean)
  • Valvetronic motor seal (experience of failure and life expectancy ?)
  • Head Gasket cover (experience of failure and life expectancy ?)
  • Head Gasket seal (experience of failure and life expectancy ?)
  • Oil Filter housing and gasket Thermostat (experience of failure and life expectancy ?) {Heard this can be very damaging as oil can leak onto serpentine belt}
  • CCV valve (experience of failure and life expectancy ?) {This can be cause of oil consumption}
  • Oil change to 5W40 (suggestions on this ?)
