mrsz3 to mrsz4
1 reading
7.6K views 10 replies 6 participants last post by  KoenTate
#1 ·
I saw this in one old post..
I went through this recently, replacing the error prone 6900727 ECU (which can be reset using specialist equipment, but why bother when it'll just fail again!) with a later one: 65776919789 - realoem shows this as exchangeable retrospectively. To change it you also have to change the 2 MRS sensors under the carpet under the front seats, I used part number 65776910678. Then recode with NCSExpert and clear all airbag errors with INPA. I now have a MRSA4 system rather than MRSA3, and no errors remain. With secondhand parts easier and cheaper than having the original ECU reset.
and I have that exact problem..
I have changed all parts and I have the NCS and INPA and the cable.. HOW do it recode it so it all works ???
please help ..
thanks.
#11 · (Edited)
CBD name it will not select automatically, but if you are interested in that name, it is better to put it in the name directly in the document. I noticed that someone is casually pointing this out, well, cbd is a very interesting product. I ordered from THC Vape Pen Archives and so far I am happy with it. If you are really interested in it you won't find anything better than here. And nowhere else is there as much variety as here. Try to order here and see what a big difference it makes.
