Hello all!
I've got a '03 mt 320i with 280,000km
I've done some research and testing but still getting some error codes with rough idle and barely any acceleration at all.
P0304 - Misfire Cylinder 4 (Pops up once idle starts "settling")
P0604 - ECM RAM Error (Instantly on ignition)
P2272 - Heated oxygen sensor (HO2S) 2, bank 2 - signal stuck lean (After driving about 10-15km)
(Through all tests the misfire stayed on cylinder 4)
So far I've done:
Found some posts and threads about mosfet failure, but from what I understood if mosfet was the issue, cylinder 4 wouldn't be getting any spark at all?
I'm all out of ideas. Please.
So far I've done:
- Swapped spark plugs
- Swapped ignition coils
- Swapped injectors
- Compression test (Good values)
- Inline spark plug test and cylinder 4 is getting spark (Did notice the light on the tester almost dies, or atleast gets really dim for a split second after touching the gas pedal)
- Vacuum leak test using the vape method - Didn't find any leaks
