intermittent misfire on a 2.8 Z3
3.8K views 7 replies 4 participants last post by  goldbcfc
#1 ·
I have 1999 2.8 Z3 Roadster with an intermittent misfire. It just comes and goes but mainly seems to lose power when I come to a stop. Tried the normal things like plugs and coils but it is still there, can go 100+ miles without an issue one day then switches off and on 5 times in 20 miles the next. Could it be injectors, ECU? Any suggestions?
#2 ·
Does it only happen when the car is cold? If so, look for a crack or hole in the rubber boots from the MAF to the throttle body. This is very common with the Z3's. You may want to have a small mirror and torch with you to inspect the under sides. The small elbow tube is a favorite failure point.
Caution: the rubber boots will be fragile, so treat them with kindness or you will damage them.
#4 ·
still have the misfire problem - But I found if I don't let the revs drop below 1000-1500 when at lights, etc. its not a problem. The loss of power occurs if the revs drop below 1000 rpm and then does not fix its self for a while.
Got to be a sensor I am thinking? Any ideas?
