Hi, So after lots of trouble free motoring I have a fault with my 320d. Fault is as follows, car starts but very lumpy, have no turbo whatsoever, the actuator moves freely when battery not connected but becomes rigid when battery attached to the car otherwise no hint of it moving. Car drives but no power as no turbo. When it does drive it can just stall, when it does it won't restart unless it feels like it and will just crank over or when it does want to restart it can just stall again randomly even when accelerating.
I've plugged it in, only engine code I've got is 3f00. Relating to Boost pressure sensor.
Am I right is saying this is the MAP sensor? If so is this likely to cause the faults above? With it disconnected car won't run at all.
Additionally looking at live data the actual pressure reading sits at 900 and never changes. The requested pressure always fluctuate depending on rpm. I'm guessing the car is asking for that amount of pressure boost but clearly isn't getting it. Whilst mechanically I'm great with tools.....the electronics side of things im getting to grips with still.
Any help or advice gratefully recieved as I'm 2 weeks into this issue and no progress!!!!
As a footnote, all started with an engine that cranked and lots of warnings such as abs, dtc, tyre pressure but I'm attributing that to low battery voltage at the moment unless anyone suggests otherwise.
Thanks in advance. JP
