Fault Codes Help Please [E46 320d 2002]
Tags
codes
9.1K views 2 replies 1 participant last post by  Jordan C
#1 ·
Hi guys
I've just read some fault codes on my car (as mentioned in this threadhttp://www.bimmerforums.co.uk/forum/f18/fuel-related-issues-%5B2002-e46-320d-se-m47%5D-t460009/ ) with a C110 scanner
The following codes have come up:
4661 - Power (to be expected, I already know battery is not up to full charge)
4B90 - Rail pressure monitoring on engine start
3EC0 - Camshaft sensor
3EC1 - Camshaft sensor
4630 - Rail pressure plausibility pressure-controlled
4600 - Rail pressure plausibility pressure-controlled
3FB1 - MAF sensor (not really likely as that is a quite new one on there so probably just needs resetting)
As you'll see from my other thread I'm having trouble getting fuel under pressure and primed. I recently changed an injector so I'm glad to see no direct injector faults, but, I don't really understand the results above. Could you knowledgeable people help me out deciphering what needs doing please :)
