F36 Active cruise control failure & front end collision warning failure.
5.3K views 7 replies 2 participants last post by  garrrs
#1 ·
Hi everyone.
Since months I have this warning: Active cruise control failure & front end collision warning failure.
Non-active cruise control works properly.
Usually the error shows up upon engine start, rarely it works for a couple of minutes after engine start, then fails.
What can I do?
Discussion starter · #3 ·
Car Scanner ELM OBD2
DTC report
Selected brand: BMW
============1==============
244800
Raw code: 244800
ECU: UnitĂ  di controllo motore
Stato: Test fallito, Test fallito (ciclo di guida corrente), In sospeso, Confermato, Test fallito dall'ultimo reset errori
============2==============
801C20
Raw code: 801C20
ECU: CAN gateway
============3==============
4827BF
Raw code: 4827BF
ECU: Suspension/Dynamic management
============4==============
482136
Raw code: 482136
ECU: Adaptive cruise control
Stato: Test fallito, Test fallito (ciclo di guida corrente), Confermato, Test fallito dall'ultimo reset errori, Indicatore di pericolo richiesto
============5==============
804182
Raw code: 804182
ECU: Car access system
============6==============
804874
Raw code: 804874
ECU: Central module (in driver's footwell) (FRM)
