E60 M5 Oil Level Sensor, IBS and Alternator Comms fault, help needed
537 views 8 replies 2 participants last post by  Johnnyroper
#1 ·
Hi, I'm hoping someone can help. I have recently become the proud owner of my dream car, an LCI E60 M5 June 2007 Model, I love it however have an electrical issue that is stopping me drive it as the oil level or temperature is not coming up.
I've got the following codes:
278F DME Intelligent Battery Sensor, Communication
278E DME Oil Condition Sensor
279B Alternator Communication Fault
Any help appreciated.
I've tried the following and loosing faith:
1. New battery
2. New oil level sensor
3. previous owner has had a new IBS sensor and alternator apparently.
4. tried to reset the codes with either of the IBS, oil level and alternator BSD Lin disconnected, all 3 come back up.
5. Checked DME connectors, look good.
6. Checked the voltage on the BDS LIN wire and it was around 2.4v and seemed to be fluctuating but I haven't had access to a scope to double check.
The strange thing is that when I reset the codes the car engine note changes and also the oil temperature gives a reading for about 20 seconds then the codes come up again and the reading drops to zero. I initially thought that there must be some comms coming from the combined oil level/temp sensor during that time however the oil temp reading came up even when this sensor was disconnected leading me to think that there may be another oil temp sensor connected to that gauge?
I haven't been to check wiring diagrams as haven't had access to ISTA, thinking I might need it to try and fault find further.
#3 ·
Cheers for the reply , I did read that out may have an auxiliary coolant pump on BDS but I don’t think it does unless I’m missing something . I did find an auxiliary coolant pump in the LHS behind the wheel arch but I think it’s just a 2pin direct on connection so thought it can’t be BDS as it would need both power and signal connections ?
#7 ·
Cheers that’s a good shout , I’m really hoping it’s not the DME as god knows how much that will cost to replace :(.
I’ve checked to ground and seems ok, I just need to check continuity now like you said , I could do with the wiring diagrams for that and I’m trying to get hold of ISTA , anyone know where I can get it from ?
Cheers Matt
#8 ·
So, checked continuity of all wires to Alternator, IBS and Oil Level , all seemed good. I managed to get a scope and checked the signal on the LIN signal wire to each component, with all components disconnected. The square wave wasn't perfect but at least there was a square wave there indicating some comms at least. The only thing is that all reading up I've been doing suggests that the signal voltage should be around 12v amplitude opposed to the <2v as shown in the image below.
Has anyone seen this before? Can anyone confirm that the LIN signal voltage should be around 12v (much higher than I'm getting). Also is there anything else I can check before going down the route of a new DME or DME repair?
Matt
