E60 530d I-Drive and electrical shut down.
21K views 23 replies 11 participants last post by  sweeper42
#1 ·
Hi All,
Every now and again on my e60 530d my I drive shuts down, head lights go off, or anything electrical shuts down, my speedo and rev counter shut down then all just come back on again in a few seconds and then i get all kinds of faults displayed, Gearbox fault, abs,run flat, check battery connections ect. i then switch off the ignition wait a few seconds then start the car and everything is ok. Has anyone else had or heard of this problem?
#5 ·
Sounds like your alternator is overcharging,Check the alternator charge rate,if you can, measure the battery voltage when the fault is occuring,the systems have a fail safe that cuts them out when overvoltage is detected
The fault memory will store overvoltage faults
#8 ·
I have been monitoring my voltage on the hidden menu (its no 9) when i turn on the ignition it shows 12 - 12.1v then when i start the engine it usually fluctuates between 14.5 - 15.1v constantly up and down, is this normal to fluctuate constantly up and down? There was one time when i started the engine it showed 11.3 - 11.6v i know that 11.3 is too low(This only happened once) but is 14.5 - 15.1 too high? or maybe this recall on the battery lead could be causing my problem? Has anyone checked their voltage and is it the same as mine? I would be grateful for any info. Thanks.
#10 ·
No not yet but i had reply s telling me it could be my alternator so thats why i posted my voltage results in the hope that someone might be able to shed a bit more light on the subject. And it only seems to happen every now and again and within the first few minutes of driving when the car is cold. When i get a chance i will take it to a garage for them to sort it out the only problem is its intermittent so it could be a nightmare to diagnose.
#11 ·
Your voltages are fine - i flattened my battery by leaving the lights on one day in Bracknell. RAC guy jumped started me and the voltage jumped up to 14.5v once started. I asked if that normal and he said yes, shows it's being charged
#13 ·
I did look at the battery a few weeks ago and i think it has been changed as it is a 100ah battery and when i looked up to see what battery i need for the car it says 90ah. How can i tell if the battery is original is there something i can check to tell? And if it has been changed what if the previous owner didn't register the battery to the car would that cause issues?And I recently noticed that when after iv been for a drive if i stop and sit with the engine off but my radio on for about 10 mins i get a warning saying low battery.
#14 ·
Still sounds like battery - even a fairly new one can fail if left discharged for a long time. The electrolyte fails
#15 · (Edited)
I only use the car on weekends and maybe the odd day in the week (i should have bought a petrol not diesel) but i have had no problems starting it and when i get the electrical shut down it only does it every now and again and its only done it within a few minutes of driving (when the engine is cold) and then i switch the engine off and then restart it again and it starts fine, there was one time it shut down 3 times one after another and i had to restart the car 3 times and it started fine i would have thought if battery was knackered i would have had trouble starting the car with not enough power to turn the engine? I have been told it could be intermittent alternator fault and the reason for the shut down is the car going into safe mode to prevent any electrical damage and would not show on a diagnostic test. I haven't taken it to a garage as it being intermittent i would have thought they wouldn't find anything wrong?
#16 ·
I think iv finally found out what's wrong as i was told it might have been my alternator as i said in my earlier reply iv been watching my voltage on the hidden menu and this morning it was 14.5V - 15.1V and then shot up to 17.8V and then electrical shut down (iv been told the car has gone into safe mode to protect the electrics from being fried by 18V). I switched off restarted the engine and it shot straight up to 17.8V and shut down again. I restarted and everything is fine again. My alternator is covered by warenty only trouble is the fault is intermittent so if i take it to a garage if they check the alternator it will probably test ok. I will have a chat with an auto electrician and hopefully sort something out.
