I didn't know you can clean actuator....
also, he said some garage said seized turbo and 1800 bill and to my surprise you all just went on like nothing happened. I would write a review to notify others about that place that steals money from other motorists! if you do nothing, this will go unnoticed. I too was a victim of few of these cowboys and I still plan to contact one who changed the oil in gearbox and calculated 17 liters of oil, plus used mine old one 3 liters saying that it was too black.....At that time, I had a EKG machine on my body to measure my heart so I didn't want to investigate or argue, but it is still on my list several months later.
back to the topic:
I had this multiple times and just to tell you, it's never ending story. I had hole even on an aluminium hose from the intercooler that was loosing the boost but diagnostics didn't pick it up. then it was EGR solenoid or actuator below the intake on the right side that I changed myself and it helped to bring some torque back, but it is not as it was before. Also, I had dislocated red charger hose for about 2x. and again there are vac pipes and plethora other things to check, such as both pressure converters for both turbos, fiddly job to even remove them and even tho, I tried it was too fiddly for my fingers so garage did it, but didnt help. But at this stage, I think that turbos are not pulling as they once were, since it has more than 130k miles on it and wear aspect comes to my mind.
but I also heard about people having hole in the vacuum granate shaped canister among other things. and lastly, as someone suggested there is that rod that pulls back when starting the car, and releasing when switching off the car, lastly it developed noisy release as opposed to before when it was quiet (about 1 minute after switching the engine). so not sure what's up with that...
