2008 E90 318i front seats changed and can't remove error 93ae, 93af and 93c1
4.8K views 4 replies 3 participants last post by  payno
#1 ·
G'day all, have just purchased a 2008 E90 318i E90 LCI and when I purchased it there was the Airbag light on the dash. I have checked the codes and it shows 3 fault codes.
93AE - Headrestraint Fault
93AF - Headrestraint Fault
These are for both Passenger and driver side
93C1 - Passenger Occupancy
The previous owner says that the airbag light has always been on since the seats were changed to M sport leather seats from the previous non leather seats.
I can only assume the previous seats had the Active Headrests and as these seats no longer have these I now get the above Headrestraint fault codes.
Although the car works fine with this light on it is rather annoying so I need to get these faults removed. I have tried to reset the airbag light but as the car system thinks there is still a fault it will not let me reset the airbag light.
I have tried the resistor trick and connected it to the Headrestraint lead under the seats (2pin white plug) but this does not make any difference and the fault is still thrown!
So the big question is if there is anyone on here that has managed to clear these fault codes either through coding or a different resistor set up?
I'm in Telford so if there is anyone nearby that may be able to sort this or any ideas via the forum then I would be interested to know how to resolve the 3 fault codes.
Appolagises if this is in the wrong section but hopefully someone can help?
Discussion starter · #2 ·
No one done this before?
I assume from the response that no-one on this forum has come across this issue before? If anyone is aware of a guide or maybe know of an answer on another forum then I would be interested to know as really want to get this sorted?
Discussion starter · #4 ·
Thanks Maxoutput, is there anyone in Uk that would be recommended to do this for me?
I'm sure there must be other BMW drivers that have had this issue when the seats were replaced so wondered who they used to get this resolved?
