2007 650 e63 steering stress?
Tags
650 e63 stress
1.8K views 4 replies 4 participants last post by  sam6er
#1 ·
Hi all, not found anything on this but wondering if it’s serious.
I got in the other day and tried to start it, no joy then got a yellow triangle with a steering wheel in it and a message saying steering lock under stress, turn wheel to start car.
Took a few goes but it started, no issues since.
Wheels were straight, not touching the kerb, flat ground etc. Only thing is I haven’t used the car for two weeks so it was out in all that cold weather.
Any ideas? Anything to worry about?
Thanks all!!
(Car has only done 28k miles)
#2 ·
I had something similar. I didn't drive the car for 2 weeks and yesterday went to the car and have lost the time & date plus message key fob battery needs charging. A red triangle on dash and error messages on idrive. I made 3 journeys and things were ok so assume it was the cold weather and 2 weeks not used. These cars don't like sitting about, best thing to do is to disconnect earth battery terminal when left unused.
#3 ·
Unlike earlier models, the E63/E64 has a electrically-activated steering lock. The problem is that it is quite feeble and can't retract again if the steering wheel is putting any strain on it - and if it can't retract you get the error message. In the old days you would fiddle with the key as you wiggled the steering wheel to release the lock - and the same is true today, just a spot of fiddling will do the trick - the error message is nothing to worry about - just normal operation!
#5 ·
I had an "active steering fault" warning message yesterday. Car has not been used for a while and battery is the original still so going on 13 years now. Restarted the car and moved the steering wheel from lock to lock and the fault went away. Not seen it since, but im guessing cold weather and an ageing battery could be the cause for me.
