1998 E36 Z3 1.9 - ASC Light on and cutting in - Pull the fuse?
8.8K views 11 replies 3 participants last post by  joylove
#1 · (Edited)
1998 Z3 1.9 - ASC Light on and cutting in - Pull the fuse?
Have moved to correct forum!
#2 ·
The z3 and a e36 are two different cars :S what one do you have ?
#3 ·
Oops! places i've looked say its a E36...well, it is a 1.9 Z3.
Basically, the car had been sitting for about 4 months before I purchased it and intermittently when on throttle it will feel like it either misfires or the asc cuts in. The light will always be on but ASC button does engage or disable ASC (have wheel spun to test) but either way the problem still occurs. If I pull the fuse(s) will that totally disable the ASC control unit? Then I can see if it is that and not the engine misfireing?
Again, apologies for my noob-ness!
#5 ·
The switch doesnt turn the warning light on or off, but it does seem to turn the ASC on and off (light stays on no matter what) and both when ASC is and isnt on I get the issue. I have found a thread about a similar issue;
Advanced Hints and Tips : BMW ABS problems
just wondering if i can simply disable the ASC control unit?! BMW near me want over ÂŁ200 + vat just to have it for an hour!
#8 ·
TBH honest I don't know the layout of your engine. But there will will be two throttle bodies (TB), the one closest to the engine is the one from the accelerator pedal. The next one back is the ASC. Follow the bowden cable from the ASC TB back to a black canister the size of a red bull can. That's the ASC actuator. Unplug the power.
Perhaps the 1.9 crowd can help with a picture of the item.
Here's the actuator
Here's an ASC TB.
#12 ·
I've unplugged mine too and accidentally started the car. The car runs a diagnostic cycle at startup. It'll detect the ASC TB isn't working and throw a fault. Plugged it back in, restarted the car, lamp goes out.
As for ABS, you likely have a duff sensor so it's not working anyway. In any case this is just a quick test, not a full time thing.
