1995 e36 320i inlet manifold swap question
3.6K views 5 replies 2 participants last post by  TheEnd
#1 ·
hi all
i am thinking of ways to give my 1995 320 a bit more accelaration on a students buget for now,
would a 325 inlet manifold fit straight on? i have read that the 320 inlet is a bit restrictive is this true? all i have on the car at the moment is a k+n induction kit which was on there when i got it and i doubt that would do much for the performance and it doesnt even have a nice industion roar lol!
the car runs fairly fast although it does seem to be a bit flat at about 3500rpm then it takes off which i like but would rather it wasnt flat at all.any suggestions very welcome cheers.
#2 ·
The manifold isn't restrictive for your engine, it has been pretty well designed, but they did also put a manifold with similar airflow characteristics on some bigger engines to restrict them.
Just putting a 325 manifold on can make things worse as the air comes down a nice large pipe, then hits a step into the smaller 320 head ports which is going to make a lot of turbulence.
In the same way a crowd would run better through a narrow passageway then they would through a slightly wider one with a step at the end.
#5 ·
i agree with you saying the 320 has a nice sound from the exhaust! how come you dont get a loud induction roar from the 320 even with a k+n cone filter? my wife has a little corsa 1.4sri and that really roars with her induction kit.
