Hi! I'm new to the forum,
I have an -00 e38 735iL that broke the transmission (0294307/ 1058 000020, BMW NR 1423300), (after mixed oil and water in the transmission), I had change the
So I bought a used 5hp24 transmission from a -96 or 97 540i e39. (0010409/ 1058 000004, BMW NR 1 422 198) I had no clue there is different versions of these transmissions.
Now I get the error code: "0F-Pressure Actuator EDS, total current".
I’m currently stuck in 4th gear and no manual mode on any gears when I select the gear shift positions. When I cleared the fault I was able to get manual 4 showing but then it went away when the fault reappeared. Also the shift indicator is fade.
Any help much appreciated.
Khalid
Hi, i have just the same problem having replaced my zf hp5 24 transmission with an earlier unit! could you tell me how you got around this problem please?
I look forward to hearing from you
Many thanks
David
