Hey all, first post here so please be patient with me!
I see a lot of posts about Z4 roofs that don't want to open... mine is the opposite... the windows drop and roof retracts every single time I unlock the car, via diamond key fob or in handle lock! Was funny the first time but now I'm wondering what's going to happen when it's pouring with rain and I need to go somewhere! It was fine a week ago (only opened remotely when I unlocked then repressed and held unlock on fob) and then all of sudden began to open itself!? I'm sure I could reprogram if I bought an OBDII cable and NCSexpert but I don't understand how it started doing it without any trigger! Thoughts and suggestions greatly appreciated!
The system is designed so if you press and hold the unlock button, everything opens up. Often if you have a faulty lock or a short somewhere it can emulate this.
Check the driver door lock, and any others (I'm not a Z4 man), and see if they feel suspect.
In the meantime, press the unlock button then after a brief pause press it again, that should stop the auto opening sequence.
