Update, put car into Local BMW service for a diagnostic, no faults found, they acknowledged there is a fault but not registering a code. The spent a couple hrs looking and check plugs etc etc but cannot find fault. Next step would be to do more in-depth. Fault finding which at £120 /hr would not be cheap. Anyone see this type of fault before ?
Brian.
Afternoon all. MY 2012, 2.0L petrol E89 auto, stalls when first started (. Car cold and ambient temp Cold). Ok if the ambient is 15degC +. Once Started it left to idle will stall, or if i put in Drive and sit on brake will stall. All ok after about 2-3 min running. Had at my local and often used garage and the cannot find any fault codes when checked. Any Ideas before i go to the local BMW dealer.
Thanks in advance
Brian
