Hi, i've got a Z3 petrol 2L 2000, it cuts out immediately after starting ( 5 seconds), i've drained the old fuel via fuel pump while replacing the fuel filter (pump working fine), plugs, checked all hoses & wires visible for damage, checked fuses with multimeter.
Any help would be appreciated
Thanks, Herby
A fault code scan is the best thing to start with.
It could save you money changing parts it didn't need.
Has it been working OK, and stopped working after the work you did? Or was the work done trying to solve the issue?
