Hi, I have an e71 m50d. The ZF 8sp transmission has an issue and one option would be to swap it out for a warrantied used unit which are remarkably cheap. The part number of the transmission is GA8HP70Z, my question is will a box from a different model ie. 335d x drive replace my unit if a GA8HP70Z unit, would there be programming required ? Etc. Any help/ advice very much appreciated
It should fit no problem but not sure if it would need coding.
A good bmw indi could code it if needed in 5 minutes.(well the one i use could)...
