Hi. I have a problem with the rough-running engine which hesitating and choking when accelerating. After checking the codes, I got a few errors. I found 3 errors that, in my opinion, may affect the power drop.: (1) 452A Info - DPF , (2) 4501 - Exhaust Gas Recirculation - Negative deviation or air mass too high , (3) 4390 Boost Air temperature sensor - short circuit to B+. For now, I wanted to focus on the last fault. After inspection, I saw that the sensor is plugged into the intake pipe but the cable is missing (?!). Unfortunately, I can't see any loose cable and I I am note sure where it should go. I enclose two photographs and want to ask to help me locate the cable and the plug. After sorting that I will perform pressure measurement on DPF to see if its clogged. Thanks for help.
270000
270001
If you put your VIN number into realoem.com you can look at the exploded parts diagrams which might help you trace where the wiring is supposed to start/end.
