Hello. Looking to buy an X3 3.0SE, 2020 model. Do they have run flats/ if not - is there a sparewheel???
220D (2018)
All BMWs now come with runcraps
but check with whoever you are buying it from.lots of people change them to get a more comfortable ride
Keep your eye on pressures on the I drive. If you get slow puncture you won’t see the tyre go down but pressure can drop to zero and then you will wreck the tyre. like any tyre keep inflated to right pressures.
Hello - so, not all BMWs have Run Flats. The X3 SE 3.0 X 2020 model has 18" wheels, Bridgestone Alenza tires (NOT the Alenza RFs). Looking on mdecoder.com for what options were built in, found no Run Flat option (S258) but there is a "Mobility Kit" listed - and on looking under the boot floor - behold - there was the Kit - pump and foam can. Now I know why the ride is so smooth.
