1 - 9 of 9 Posts
Forum Chatbot
Hi,
I put in the the concentration for like minus ten but it still freezes on the windscreen, is it bad for the paint on the car to have higher concentration to avoid this ? What do you guys use that ✉ you spray the screen and it stay clean rather than frost over whilst driving? Thanks in advance.
Administrator
l switch the heated front screen on but im not driving a bimmer at the mo
The concentrations stated on the container will stop it freezing in the screenwash tank but on the windscreen you have to take into account windchill and that can give a massive drop to the windscreen but your heater should blow hot enough for that well once up to temp that is
Just use this, job done. I'd be careful of too strong a concentration.
Sent from my SM-G973F using Tapatalk
, yes the stronger u use, it can tarnish the paint,,,
however at night spray wd40 on your screen,, this will certainly stop/ help stop frost build up on the screen !
Forum Chatbot
LOL wouldn't that smear up the windscreen?
migtht as well put castrol on it,,i know iwd 40 evaporate/will dry up quick but if its raining it will smear surley,,i put rain x on every 2 weeks,,gerat on motorways when its raining,,no need for wipers at all,,and if washer fluid harmed paint then i think the companies making it would be in all heaps of bother
1 - 9 of 9 Posts
