Hi guys, a little help here, please:
2011 E91, I pull the handle, I hear the sound, but instead of a spray, I only get a few drops out of the nozzle. At first I thought it could be the nozzles, but I don't think so.
I removed the rubber pipe that comes down from the motor under the bonnet (see picture):
There is a bit of water coming from the rubber pipe, but not much, and the motor is working 'cause I can hear the sound...
What can it be?
Does the rear washer work? Have you checked to see if it's leaking anywhere else? fill tank up, give it a good squirt then check around the car and wheel arches for puddles. Also get someone else to squirt em while you trace the pipe from the tank to the nozzles. Could be split pipe or connection come away. Splits are common especially if fluid over diluted in winter.
Most likely a blocked pump filter. Do a Google search - there's plenty of DIY guides on YouTube...
sounds like some gunk is blocking the flow.. I would give the pump and pipes a clean before spending any money on it
Plus one on the strainer/filter
