Had Autoglass out today but we couldn't get the wiper arm off.
Needs a special tool.
Can anybody help please
TIA
Moderator
Never had to remove it - but the Torx bolt is because you have speed - sensitive pressure adjustment. Are you sure you don't have a bolt going across the arm? Number 9 below:
RealOEM.com - Online BMW Parts Catalog
Hi Timm,
I popped in to see a supposed specialist near me, you need a torx T80, undo the bolt, there's a dowel in there, which helps with the spring pressure, remove the dowel then use the torx again and hey presto the arm came off easily.
I've just looked at the wiper arm and can't see any bolt that might have helped
