Why Poly?
Polyurethane bushings are stronger and last longer than standard rubber bushings. Most modern production vehicles are designed using rubber bushings which have a limited lifespan. This contributes to suspension failure due to vehicular weight and the inherent design of high-tech suspensions. Typically this results in less than desirable vehicle handling and can cause many related parts to wear out more rapidly than necessary. Polyurethane corrects this problem and in many cases improves vehicle handling and drivability.
Our control arm bushings come with a lifetime warranty.
Two Reasons Our Bushings Are Successful:
• Design – The sleeves in our bushings freely rotate which enhances longevity.
• Installation – Once removal of original bushings has taken place, installation of the new polyurethane bush typically takes from 1 – 5 minutes to install, the techs love it!
For more information please visit our website - www.psbushings.com
Our eBay store - stores.ebay.co.uk/psbushings
