hi all,
can anyone tell me where is negative lead on m54 6 cyl engine?
i found 8 leads coming from DME to ignition coils (one FAT red, thick BROWN and 6 BLACK multi coloured)
there are coulpe of pics. which one is which?
thank you
The Red & Brown is split into 6 Red & 6 Brown cables after they exit the DME; the "black & colour stripe" wires run to each coil individually to pulse the ignition signal to each coil.
Coil 1
Red wire - main power
Black & White - pulse from ECU
Brown - earth
Coil 2
Black & Red - pulse from ECU
Brown - earth
Coil 3
Black & Yellow - pulse from ECU
Brown - earth
Coil 4
Black & Blue - pulse from ECU
Brown - earth
Coil 5
Black & Green - pulse from ECU
Brown - earth
Coil 6
Black & Purple - pulse from ECU
Brown - earth
HTH
