Hi,
A rat has chewed this wire (as pictured) under the bonnet.
It’s a cable that’s visible when you open the bonnet and runs above the engine cover. Unfortunately it then gets ticked away either side and I can’t see any labels or numbers on it.
Anyone have an idea what it is?
Looks like it’s wiring harness as identified by Cotswold BMW, saying the following:
After speaking to a technician and having a look in the catalogue, the most we can see is that the wiring you require only comes as part of a new engine module wiring harness - We are not showing any repair cables sorry.
Part number 12518510275 - However there is a note attached which says there is a possibility of two other numbers depending what is on the car currently. 12518518799 + 12518514831 - the only way to know is to check the label on the harness.
