V8 650i Convertible - LPG conversion? Cost / UK company?
1.2K views 3 replies 4 participants last post by  krisbiker2
#1 ·
Hello Bimmers,
With £2 petrol/ litre on the horizon I am keen to learn pros: cons of LPG conversion and lack of boot space may make this a non starter?
All advice as an LPG virgin wellcome?
#2 ·
You need to go to a specialist Lpg Center
Give kevin a call and mention my name
BW chiptune
-Tuning BMWs since 1991
-Dyno Dynamics rolling road.
BW autorepairs
-Over 30 year repairing BMWs.
-BMW Ecu repairs.
-EGR programmed to stay closed all the time
-40% of my work is repairing the problems that are caused by other tuners Remaps
UK
0208 561 1818
07831 103030
Unit 8&9
alpha industrial estate
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+34643890040
+447831103030
#4 ·
I ran a Lpg E60 for several years. If doing high milage it's worthwhile, the only reason I went to diesel was that BMW went to direct injection and no kits were available to fit. I don't know if that has changed now, but if your car has direct then that's a consideration.
Don't bother with a cheap kit or fitting, go for brc or prinz otherwise you are likely to have reliability issues. They will cost you in excess of £2000.
Your mpg on gas will be lower than than on petrol, from memory it was about 80%. When I had gas, it was half the price of petrol, now it's only approx 2/3 so the saving is a lot less, the payback for my system was break even at about 40k miles. So it takes a while to just get your money back.
If you have a spare wheel well you can have a donut tank, means you don't lose boot space.
It may sound as if there are a lot of negatives in this answer, don't get me wrong, I think it's the best fuel for a car and is more planet friendly but even if DI issue has been sorted I would struggle to justify due to the lower miles I now do.
