Guys I wanted to ask, I have a e92 325d 2008 with the m57n2 engine, now the older ex 335d had the same engine m57n2, can I bolt on the 335d twin turbo without blowing the engine?
2013 BMW estoril blue f30 330d
Do they use the same fuel injectors? You’ll need it all mapped in to ensure everything is running ok
Vendor
It would be less expensive to sell your car and buy a 335d
The other problem you will have is trying to insure your 325d after the mods
BW chiptune
-Tuning BMWs since 1991
-Dyno Dynamics rolling road.
BW autorepairs
-Over 30 year repairing BMWs.
-BMW Ecu repairs.
-EGR programmed to stay closed all the time
-40% of my work is repairing the problems that are caused by other tuners Remaps
UK
0208 561 1818
07831 103030
Unit 8&9
alpha industrial estate
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+34643890040
+447831103030
