1 - 1 of 1 Posts
The 2010 X5 e70 prop shaft came off and lashed into the casing on the automatic gear box. Now the prop shaft is fixed without help from BMW although this model is October 2010 built and within the range of the faulty x5's that have had a lot of these same failures,now the car judders and the transmission is also broken.
The AA dragged the car whilst in park on 3 occasions in order to the recover the vehicle before taking the pin out that enables you to move it.
Could the dragging of the vehicle onto a flat bed be the cause of the latest problems as it was only the outer case that seemed to have damage when the prop shaft whipped off? Has any one any ideas please? The car cost 21k and doesnt seem to be a very good buy at the moment:-( Thankyou
1 - 1 of 1 Posts
