Hi guys,
It sounds a bit of a ball ache to fit the 16:9 screen complete with the satnav.
Is it possible to fit the unit, but not have the satnav, gps, or antenna connected?
Would everythng still work? Radio, multichanger, steering wheel and bluetooth?
Thanks for any help,
Dazz
Uber Platinum BFuk Member
Has your car got all the wire already in ?
You can unplug the sat nav in mine and rest still works as it should, does that help you.
Apologies, its a 330ci with the business unit in at the moment. Are there any additinal wires i might meed or will the existing one just work.?
You'll need a lot of wire going from the front (radio) to the rear where the sat nav, cd changer and TV boxes are, it's a loom full of wires.
