Hi
Sometimes when in DRIVE and when Im stopping the car RPM goes up to 1.5k or so. Sometimes when I put stationery car in D it does the same. Its like sudden RPM raise for half a sec and then it drops to normal.
Any ideas?
do ypou not mean going from d to ds mode,,as this bliops the revs up and gear..also when coming down the gears the car will be going down gears and the revs pop up..like with any manual car..do 40 in 4th,,change to 3rd and the revs will rise..
It does it when I change from P or R or even N to D or R. Also happens when Im slowing down when car is nearly stopped. RPM go up for half a sec and you can feel car pulling so much I need to step on brake rly hard to stop it from moving
