Good afternoon all,
as the title says, I'd like to know if it is a straight swap between the stock 320d bushings to the M3 ones?
I'm preparing to do an overhaul of the rear suspension and would like to get M3 subframe bushings while I'm at it, but haven't had any luck in finding the info if they fit?
Please can someone confirm if they fit a standard 320d?
I have checked that, and they are different part numbers, but if the diameter and size of the bushings is the same and the bolts are too, maybe it could be straight swap..?
Sorry for not answering your question, but if the subframes are not the same, wouldn't be better that you pick something not-OEM but specific for your car instead of trying bushings that are not even designed for your joints?
You can check the Powerflex for instance.
Sent from my SM-J500FN using Tapatalk
