If you have the key with the large round button nearest the key and 2 smaller buttons side by side nearest the key hanging loop then this is how to program it.
1.Unlock vehicle and enter it, close door, switch ignition ON and OFF again, remove ignition key.
2.Press and hold the unlock button, while doing this briefly press lock button 3 times within 10 seconds, release unlock button.
On some models the LED on the key will flash slowly for around 10 seconds, other models the central locking will lock and unlock rapidly to indicate correct procedure. Some models you may need to try this more than once and upto 4 keys can be programmed but no more. Programming needs to be carried out for each individual key within 30 seconds.
Hope this helps :thumbsup
Any questions and I can be found here on this forum, never on here anymore. http://www.bmwforums.info/forum.php
