1 - 10 of 10 Posts
Hopefully someone can shed some light on the strange issue I'm having.
Below I have listed the symptoms.
Window switches not working (works on the key)
No backlight on the clocks
No indicator flash/tick on dash
Car door signal screen on clocks not working
Wiper stalk not working
And probably more I've not found yet!
I have checked all relevant fuses in the glove box but all seem fine.
Has anyone ever experienced this or something similar?
Have they been working and all went off at the same time, have they never worked, any faults showing on the dash, and have you used an obd reader to check potentially recorded faults?
I've not long had the car and have not yet had it plugged in to any diagnostics. The guy I purchased from said it all stopped working at the same time out of nowhere
Hope you got it cheaply.... Dunno if I would have gone through with the deal with something wrong without a sweetener or promise to fix it.
Bought mine with abs problem, fixed before I picked it up...
Yes I got it cheap enough. Just hoping I can get this issue sorted so I can enjoy the car!
I'd suggest you need to get it scanned for faults and see if any electrical modules have issues.
1 - 10 of 10 Posts
