Just back from having a BMWP exhaust fitted to my E92 330i
I think it looks great and being OEM was a perfect fit.
It's actually quite quiet! Raspy at higher revs.
One thing tho, the valve is open all the time? Could this be that it's been fitted wrong?
Some pics to wet your appetite.
Discussion Starter #2
Does anyone know how to get the black plastic valve bit off? i would like to check it is connected properly..
cheers
Looks nice mate, think your find that the valve is open when the car is not running, see if it closes when you fire it up?
Where is the other end of the vacuum tubing going as it looks like it has been disconnected.
The flap is only there to keep the noise down at below 2,500(ish) rpm and first thing I did with my 335i was disconnect it to keep it open.
