Hi all,
I have a 2017 f31 touring with a damage led headlight. I have found a replacement unit however I’m unsure if this this the correct replacement or not. Please could someone advice if this to parts are the same according to there parts label!
thanks
269700
269701
Put the last seven of your vin number into realoem you will find every part number of every part of your car.
The part number shown on the labels is not shown on realoem, i am getting the information from the right label or is it some where else on the headlight unit?
It's the right label but the codes slightly different I would say it's not the correct part but it 'could' fit
Does anyone know what ‘ECV526’ on the label means? Have fount another unit which has matching part number however the ‘ECV526’ part of the label is different. Does this matter?
269707
Could it be the same part, with a different country designation, in which case the aiming or pattern of the light might be wrong for UK. If it's cheap enough maybe just try it!! The voltages seem to match ...
