Took this from another Site
ALPINA B10 V8(e-39)
This is the first Alpina car based on the latest 5-series generation, the e-39. It was introduced in March 1997 and it is still in production. When it was introduced it was considerably cheaper than the B10 4,6 it replaced. For 1999 Alpina updated the B10 V8 with a improved engine with double VANOS. That makes the car both more powerful and more frugal. It is around 17000 D-mark cheaper than the new BMW M5. This summer BMW introduced a facelifted 5-series, so all the B10´s from September 2000 will receive the changes.
Engine/Gearbox
The B10 V8 is based on the BMW 540i, which has a 286 bhp, 4,4 litre V8 engine. The easiest way to get more power in a engine, besides turbocharging and supercharging, is to increase the displacement. The usual problem when increasing the displacement on a BMW V8 engine is that it has Nicasil-coated bores so you can´t just overbore the block, you have to cast a whole new block. So BMW casts new blocks for Alpina with the displacement increased to 4,6 litre. Alpina have also made some other changes to the engine such as a new crankshaft, more enterprisingly timed cams, hand-fettled ports, lighter higher-compression Mahle pistons and reprogrammed the Motronic system. The result is 340 bhp and 470 Nm of torque at 3800 rpm, 100 rpm lower than standard. For this model year the engine has double VANOS. The engine now produces 347 bhp, probably more if you look at the much improved performance figures, and a torque of 480 Nm. The B10 V8 has a ZF 5-speed automatic gearbox with the steering wheel mounted Switch-Tronic system.
Suspension/Brakes/Wheels
The B10 V8 has twin-tube gas pressure shock absorbers at both front and rear. It also have new anti-roll bars. The brake discs are ventilated all around and have floating callipers. The Alpina alloys are 18in high with 235/40 tires at front and 265/35 at rear. Michelin tires of course. But as an option you can have your B10 equipped with 19in wheels.
Interior/Exterior
The interior changes are not many, the steering wheel is hand-stitched and the BMW´s sport seats are fitted with anthracite cloth with blue and green stripes. You can have the car with Alpina instruments which are blue with red needles and the speedo shows 320 km/h. Alpina also fits its own wood and soon you can have it with Alpinas own sports seats. The visual changes are a new front spoiler, rear spoiler, the wheels and the exhaust pipes.
Performance
Alpina claimed a 0-100 km/h time of 5,9 seconds and a top speed of over 275 km/h. For the touring they claimed 0-100 km/h in 6,2 seconds and a top speed of 268 km/h. In Auto Motor und Sport´s test the B10 accelerated from 0-100 km/h in 5,7 seconds, 0-160 km/h in 13,0 seconds and 0-200 km/h in 22,3 seconds. In Auto Motor und Sport´s test of the B10 V8 model year 99 against the new BMW M5 and BMW 540i, the B10 accelerated from 0-100 km/h in 5,4 seconds, only 0,2 seconds slower than the manual M5, 0-160 km/h in 12,5 seconds and 0-200 km/h in 20,6 seconds. The top speed was 279 km/h.
