Hi all as you can see im new to the site :)....I currently have a problem with my car and was hopeing you guys could help.
I have a 2007 530d saloon and just did the swirl flap blanking mod.plugged everything back in, and for some reason when the maf is plugged in i have no throttle but have throttle when its not ....?Ive tryed a brand new one and it does the same.... very confused .... hope you guys can help .
Do you have a serious air leak somewhere?
Generally if you have a new problem after working on a car it is something you did so recheck everything you touched and anything you may have knocked
Check again because it's 99% probable what you touched is the cause.
A large amount of unmetered air is a likely cause.
What did you bumg the swirl flap holes with? Any pipes under manifold missed?
If it was mine I would spray some easy start or similar around and see if the revs climb if it is being drawn into the manifold but it is not mine and I would not recommend it so do not do that.
I used wet tissue to bung the swirl flap holes .......lol I used the proper blanking plates. ill have to take it apart again tomorrow .
