Hi guys new to the forum
Am a member on another forum though
Just wondering if anyone has encountered this problem I'm having
Basically the car is undrivable when the maf sensor is plugged in
I've changed the maf sensor but car is the same hardly any boost or when it does it's not till over 2000rpm
Car runs fine when maf is disconnected but also when the vac pipe on the egr is pulled off
I've just taken off the air intake manifold as I could see oil running from the ports
Looks like either the seals are shot (seals look ok to be honest) or it's leaking from the actual bottom of the swirl flap. So I've ordered a blanking kit...not got much hope in it fixing my problem though. Could this cause my boost problems
Any ideas would be much appreciated
