Hi Everyone,
Hoping there's someone out there who may have had this issue before and knows what I'm overlooking. I've got a 58 plate E92 320D (N47 engine). Car was working fine and was due its service. I changed it's oil, filters, and glow plugs as I don't think they'd ever been done before. Battery was off for a good few hours whilst I got all the connectors out and the manifold off to get at the glow plugs. Changed everything out fine and connected it all back up as it was before. Now I'm getting a yellow engine warning light on my dash. I've checked on INPA and all sorts shows up. If I clear them off, take the car up and down the road for the light to reappear and check again I get a different mix of codes, very confusing.
S0074 - No Communication with CAS
S0114 - No Communication with Control Unit
S0180 - No Communication with Safety Module / Restraint System
S0212 - No Communication with Junction Box Electronics Gateway Module
003FF0 - Air Mass Mesaurement
004933 - DDE Air System Air to EGR Mass Flow Plausibility
00FFF1 - MOSTSYS No Communication to Head Unit
Along with the occasional DDE communication and DSC communication error.
It seems to be random which ones come back although the CAS one seems to be fairly consistent. The thing is everything in the car works fine. It drives fine, all the buttons and features work as they should so I cannot work out what's broken. The only difference between the before and after is that the car seems to shudder when the engine is turned off. Other than that everything is exactly the same as it was before servicing.
Is there some sort or fuse or relay that could have got stuck? Completely at a loss and would rather fault find myself than pay a dealer ÂŁ100 an hour.
Thanks.
Thanks.
